capacitance -current flow in a swiched circuit with a capacitor
Discussion in 'General Electronics Chat' started by sharanbr, Jul 5, 2015.
  1. sharanbr
    Thread Starter Active Member
    Apr 13, 2009
    76
    I would like to understand how the attached circuit with capacitance would behave.
    Initially - S3 & S4 are closed. S1 and S2 are open.
    Condition 1 - S3 & S4 are open. S1 is closed and S2 is open
    Condition 2 - S3 & S4 are open. S1 is open and S2 is closed
    Under condition 1 - electrons would flow from C and through R1?
    Under condition 2 - would electrons flow through R2 and into C
    How potential plays a role when S3 and S4 are open.
  2. BillB3857
    Feb 28, 2009
    2,402
    348
    Do a little thought exercise and see if you can come up with the answer. What would be the voltage and polarity on the capacitor after the initial condition? What happens when condition 1 takes place? What is the current path for each condition? What is the current path for Condition 2? What happens then?
    Are you sure you have the switches numbered properly?
  3. dl324
    Distinguished Member
    Mar 30, 2015
    3,384
    653
    It might be easier for you to visualize current flow, or the lack thereof, by connecting the two points labeled as ground, and removing the ground connection because neither side of the battery or cap is grounded.
    With the capacitor charged, S3 and S4 opened, and only one of S1 or S2 closed, can you see a path for current to flow? Note that I also flipped your schematic so the positive battery terminal is on top.
  4. sharanbr
    Apr 13, 2009
    76
    Dear Bill,
    S1 closed; S2, S3, S4 - open
    My initial assumption was that current flows in R1 -> C direction (and electrons in the opposite direction).
    But after looking at the posts subsequently, I think no current can flow, as the other end of capacitor has no path to react to this changing status on the upper plate.
    Assuming my interpretation above is correct, I have a follow-up question.
    If S1 and S4 are closed; S2 and S3 are open, would it mean that circuit is complete and result in current flow across R1?
    Similarly, if S1 & S2 are closed; S3 & S4 are open, would it result in current flow?
  5. BillB3857
    Feb 28, 2009
    2,402
    348
    Draw the circuit in each configuration you mention. Trace with a pencil and see if you have a complete path to either charge or discharge the capacitor.
  6. sharanbr
    Apr 13, 2009
    76
    Dear Dennis,
    My understanding was (I am saying 'was' as I am seriously doubting it now) that S1 being closed is sufficient for current to flow.
    Now, I realize that probably circuit has to be complete in some form.
    So, I have put another figure. Does this result in current flow?
  7. MikeML
    Oct 2, 2009
    5,451
    1,066
    Nope. There must be a conductive path from the positive terminal of the battery to the top of the resistor for any current to flow...
    Repeat after me: "there must be a complete loop for current to flow".
    I thought we dealt with this in your other thread?
  8. sharanbr
    Apr 13, 2009
    76
    Sorry about that. I will keep that in mind.
  9. BillB3857
    Feb 28, 2009
    2,402
    348
    If you start at a point and trace the circuit and don't wind up back at the starting point, you don't have a complete path.
  10. WBahn
    Mar 31, 2012
    18,089
    4,917
    Help people help you. Provide a sketch for each configuration along with your question. This doesn't take much time and greatly increases the chance that people will take the time to respond and greatly decreases the likelihood of miscommunication. For instance, something like the following:
    I have a circuit in which S3 and S4 are closed while S1 and S2 are open:
    I then have two conditions I want to ask about.
    Condition 1: S3 and S4 are open, S1 is closed, and S2 is open:
    Condition 2: S3 and S4 are open, S1 is open, and S2 is closed:
    See how much easier it is for someone to follow what you are saying and asking?
  11. WBahn
    Mar 31, 2012
    18,089
    4,917
    You Condition 1 basically comes down to the following:
    Will current flow in this "circuit"?
  12. sharanbr
    Apr 13, 2009
    76
    Dear Bahn,
    My answer in 2 parts ... (what & why)
    what - i know that current would not flow through this as circuit is not complete
    why - i don't know why this happens. I guess that for current to flow two nodes, they just have to be at different potentials
  13. sharanbr
    Apr 13, 2009
    76
    Sure. Will do hereafter ...
  14. WBahn
    Mar 31, 2012
    18,089
    4,917
    For current to flow between two nodes, they do not HAVE to be at different potentials, but this is usually the case. The counter example is a superconducting magnet.
    But you DO have to have a complete circuit (there ARE cases where this is not strictly true, but you will almost never run into them).
    I think I have recommended this to you before, but if so it appears you didn't read it.
    http://forum.allaboutcircuits.com/xfa-blog-category/circuit-analysis.37/view-entries
    If you have current flowing onto (or off of) one plate of a capacitor and not the other, it takes very little current to result in a net charge on the capacitor (as a whole) that will built up enough of a potential difference to start arcing.
  15. sharanbr
    Apr 13, 2009
    76
