Sorry for this novice thread but I've just started learning electronic and I've some problems to understand some concepts and I hope you guys can help me to grasp them, hopefully.
1) In my lesson book it says that the density of charges = D = Q/S (S = area).
Well that makes sens.
Then it says :
Q/S = D = E . ε. I'm not sure I get this last part on so many levels.
First of all I don't see why the substance between two charges comes to play a role in the value of a voltage or an electric field. How I see it at the moment is if two charges are bigger then the voltage is bigger. I don't really get that "ε".
2) Capacitance:
My book says the capacitance = C = Q / U . I just don't get it. First of all voltage must relative between two charges. Here we have Q, but which Q is it ? Any of the two Q of the two metallic plates ? Also for me the word capacitance means : If I have a bottle, the capacitance of that bottle is the amount of water I can put in that bottle before the water starts to come out.
I don't see the link between my definition of capacitance and C = Q / U, I just don't see how this formula can give any info on the capacitance of a capacitor since the Q is supposed to change over time.
( 3) In coulomb's law :
F = k . q.q' / d² with k = 1/ 4πε. Well I understand that there must be a proportionality between the two charges' magnitude and the force and an inverse proportionality with the distance. I don't get what the "k" role is there and how it's calculated. )
I'm really grateful if anyone could try to answer my questions because I'm really confused. My third question is the less important of the three for me tho.
Then it says :
2) Capacitance:
