You should see some of the capacitor banks I've seen back when I worked around lasers. Most were housed separately from the actual supply and triggering/driving circuitry and had safety interlocks. If you had to bleed one it was an overnight situation.Capacitors in those monsters can run 350 volt, as high as 2K μF, and usually a gang of up to six is the lartgest I've seen / worked on.
And then you had to replace some power transistor mounted on a beryllium oxide (can you say brittle?) insulator.If you had to bleed one it was an overnight situation.
I can certainly appreciate that....one thing I get a charge out of [[ OK ... lousy pun ]] is the current crop of "Fast & Furious " wannabes with the 1000 + watt "ghetto blasters " they install in their hotrods. Part of the system to power the subwoofers in these monstrosities, are caps in excess of a farad or moreYou should see some of the capacitor banks I've seen back when I worked around lasers. Most were housed separately from the actual supply and triggering/driving circuitry and had safety interlocks. If you had to bleed one it was an overnight situation.
Thread starter | Similar threads | Forum | Replies | Date |
Bleeding capacitors in circuit and out of circuit | Analog & Mixed-Signal Design | 2 | ||
Netflix - "The Bleeding Edge Documentary" | Off-Topic | 0 |
by Duane Benson
by Aaron Carman
by Jake Hertz
