I'm writing a program to move a servo on a 16f684 in assembly and I ran into a very simple problem that I just can't figure out. I am not able to write anything to port a. I'm simulating it with mplab sim and there is no change on port a. I have all of the code written and its just that that is the problem.
The code below is the beginning of my program. port a is supposed to start cleared, but just to check if it was working I write to it. There is no change bit 0 doesn't go high. I just can't figure out what I'm missing.
Rich (BB code):
Start ;configure ports
banksel TRISA ; configure PORTA
movlw b'111110' ; pin 0 only output
movwf TRISA
; configure TMR0
movlw 0<<T0CS|0<<PSA|b'110' ; timer mode (T0CS=0), prescaler, 1:128
banksel OPTION_REG
movwf OPTION_REG
; initialize variables
movlw .90
banksel pos
movwf pos ; default position 90 degrees
banksel PORTA
movlw b'111111'
movwf PORTA ; set servo pin low
; configure interrupts
movlw 1<<GIE|1<<T0IE ; enable timer0 and global interrupts
movwf INTCON
