Cant oscillate sine wave from "bubba" oscillator
Discussion in 'The Projects Forum' started by LFU, Apr 3, 2010.
  1. LFU
    Apr 3, 2010
    Hey,
    Mt project is DC/AC inverter.
    In this project i am using a "bubba" ocsillator as a sine ref circuit.
    Whan i am tring to simuliting this ocsillator using "Pspice" i get a DC wave at the outputs.
    whan i have wireup'd this circuit in reality i have succssfully saw the sine wave.
    why i cant see sine wave in Pspice?
    thanks!
    Liran
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What is your simulation start and stop times, and what is your step?
    Do you skip the initial operating point?
    R7 and R8 should be adjusted for about 1.2v out (R7=9k, R8=1k), and connected directly to U6 pin 3. Remove U5C. A TL08x opamp can't get within 3v of the negative rail, so it's not really suitable for a voltage follower for a voltage that close to the negative rail.
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    Your schematic has too many ground wires, supply wires and crossed wires all over the place. If you use ground symbols, use + supply symbols and uncrossed all the crossed wires then it would look neat and tidy like the one you tried to copy.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    What is your op amp?
    What is the resonant frequency?
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    The schematic shows the antique LM348 (a quad 741).
    Texas Instruments sine-wave oscillators document says 1.72kHz when a fast opamp is used.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    He needs a different op amp. LM348 won't work with 1.2V on the inputs either.:(
  7. JoeJester
    Apr 26, 2005
    3,393
    1,211
    TLV 2474 was used in the bubba oscillator in TI's Op Amps for Everyone.
    on edit ...
  8. Audioguru
    Dec 20, 2007
    9,411
    896
    If you do not power it properly or if you short its output with an impedance less than about 1k ohm then the oscillator will not work.
    An 8 ohm speaker as its load shorts its output. Use a power amplifier to drive a low impedance speaker.
  9. Y2J
    Feb 17, 2011
    I have Dc/Ac inverter circuit that same with LFU, using 1r2110 as gate driver of IRF20n50k and bubba oscillator as oscillator. I tried simulate it using PPSPICE and Proteus but it did not functioning. Does anybody here know how to solve this? I doing my project upon this topic. Need help. TQ.
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    IRF20N50k does not seem to be a good part number.
    Trying to use a "bubba" oscillator or other sine wave oscillator as an input to an IR2110 gate driver won't work; you would need other circuitry.
    You have not posted an image of your schematic, so we have no idea what to tell you.
  11. Ron H
    Apr 14, 2005
    7,050
    657
    I thought maybe he was trying to use the Bubba oscillator as the reference for a true sine wave output inverter.
  12. Audioguru
    Dec 20, 2007
    9,411
    896
    Yes it is.
    But it uses the wrong opamps and is biased wrong.
