Debe,
thanks for pulling this info for me.
I did locate some BOSCH parts yesterday, however.. here is the situation. I'm attaching the current hook up schematic of bike's regulator. So...below are regulator types that I was able to find datasheet so far
- 78H12 (5A) - case is common...doesn't match up, my opinion
-LT1038 (10A)/LT1083(5A)/LM138 (5A) - I think this is what installed in original, as pinouts match as per your explanation, i.e. the output is fed to input throught the rotor...or am I missing something? This is the tricky part to sort....
- LM396 (10A) is another variation, and also to me is not applicable.
Need to get around this...
p.s. all, pls post all the regulator types that you are aware of and are capably of >=10A, and as per 2nd bullet regulators pinouts.
