Hey folks - after smoking my 4th power transistor, I thought I should turn and get some professional help.
I'm trying to drive a biggish magnetic coil (that's the sketchy inductor in my schematic). The desired output is a 5-6A DC current with a maybe up to 1A 60Hz sinusoid.
Everything works fine for about 3 minutes and then I blow the collector emitter junction, the smoke comes out, and I can't put it back in.
So, where am I going wrong? The transistor (I'm using MJ15024G) is rated to 250W, it is mounted on an old Intel P2 heat sink, with a GOB of heat sink grease. The heat sink gets quite warm to touch, but still touchable so probably around 60C. The power supply is a beefy lab unit that can easily pump out 30amps at 40V.
Any and all suggestions greatly appreciated
