Can't Identify this component.
Discussion in 'General Electronics Chat' started by kdcouture200, Mar 3, 2015.
  1. kdcouture200
    May 22, 2010
    17
    2015-03-03 17.15.03.jpg So I've been trying to figure out what this part is. I'm guessing is a resistor pack but I'm not sure. Any help in identifying this part would be greatly appreciated. Thanks
  2. GopherT
    Nov 23, 2012
    6,309
    4,030
    You are correct. There are various connection formats. Check the datasheet for this one. RES0180 looks like the right number.
  3. kdcouture200
    May 22, 2010
    17
    Couldn't find a datasheet on it.
  4. Dodgydave
    Jun 22, 2012
    5,153
    770
    looks like its a resistor block, try reading the pins with an ohm meter.
  5. kdcouture200
    May 22, 2010
    17
    All pins seem to be connected together. Every pin seems to have a different resistance in respect to one another, its an odd first one for me.
  6. Dodgydave
    Jun 22, 2012
    5,153
    770
    usually one pin is the common, youneed to remove it for measuring.
  7. Lundwall_Paul
    Oct 18, 2011
    222
    19
    Resistor packs come in two verities. You may find nine independent resistors of the same value or all resistors have a common connection which are frequently used as pull-ups.
  8. OBW0549
    Mar 2, 2015
    1,393
    939
    It's a resistor pack, all right; made by CTS. I'm guessing it's a 16-bit SCSI terminator: one pin for GND, one pin for VCC, and 16 data lines.
    That's my guess, anyway...
    Lundwall_Paul likes this.
  9. bwilliams60
    Nov 18, 2012
    734
    94
    Can you show us the rest of the board? What is it out of?
  10. kdcouture200
    May 22, 2010
    17
    Its out of a car alarm module. It connects to the reciever for the key fob.
  11. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    I think there are only a few limited configurations for standard resistor networks. You could use a datasheet like this one, and using an ohmmeter, determine which of the schematics matches your network. Is it possible to unsolder the part?
  12. kdcouture200
    May 22, 2010
    17
    I did as you suggested and found (i hope) the configuration of the pack thanks everybody's help.
