Can't identify old part from 1976 DC motor controller
Discussion in 'General Electronics Chat' started by Stevereno, Jan 12, 2015.
  1. Stevereno
    Jan 12, 2015
    I'm attaching two photos of an unknown part from the speed controller of a 1 hp DC motor on a potter's wheel built in 1976. I have had no luck finding it via Google, although to be fair I'm not a search expert. I'd really like to fix the wheel but since I don't know what this part is/does, I don't know if it's malfunctioning or what I would replace it with.
    Here's a brief description, in case it's not clear from the pictures. The part is stamped on the top with the number "30" in a circle. The case is black plastic (possibly bakelite?). It has six round wire legs (not flat pins like an IC chip). The legs protrude upward from two plastic "shelves" on either side of the part (three per shelf), then bend around 180° to stick down into the circuit board. On the bottom of the part is stamped
    NPI
    PA-2392
    7435
    Also stamped on the bottom are the numbers 1 through 6, corresponding to the round wire legs.
    Does anyone know what this is?
    Thanks!
  2. tcmtech
    Nov 4, 2013
    2,111
    1,751
    Most likely a old style pulse transformer for triggering an SCR.
    Stevereno likes this.
  3. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
  4. Stevereno
    Jan 12, 2015
    Very cool! I looked up "pulse transformer" and found the attached pdf from 1999 for a Rhombus P/N T-1214. This looks very much like the unknown part, and, on my circuit board legs 6 and 4 are connected to the gates of two thyristors. Thyristors and the like are all brand new to me, so if you don't mind would you confirm that this is consistent with it being a pulse transformer?
    Thanks again!
  5. GopherT
    Nov 23, 2012
    6,309
    4,029
    You might be better off saving the motor and buying a new DC speed controller. 1976 is getting pretty old for something like this.
    Might be able to find something on eBay for $100 to $150. On the other hand, if you are able to safely make it work and have the time & interest, then go for it.
  6. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
    I am guessing it is a 1:1:1 pulse transformer, these were common for that vintage, I used to get mine from Hammond, they should be still available.
    If you were to reverse engineer it you could also use the later method of a couple of Triac output Opto's.
    KB make modern SCR drive boards for DC motors.
    Max.
  7. Stevereno
    Jan 12, 2015
    One more question ... in the schematic of the Rhombus pulse transformer above, what does the black dot mean on pins 1, 3 and 5?
  8. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
    It indicates the start point of each winding or that the windings are all wound in the same direction (in phase) from this point.
    Max.
