Self-assigned homework: I thought I would try some different capacitance values in a simple bridge rectifier circuit. For me, step 1 is to make a working bridge rectifier circuit before adding capacitors. I basically recreated one of the many online bridge rectifier schematics, but a time-dependent voltage graph of the output shows I have failed. I checked the wires and diode orientations a half dozen times. I am guessing that the problem is with my grounding, since that isn't displayed in the diagram I am copying. Multisim (trial) won't run circuits without a ground and there must be a good reason for it. What have I failed to grasp in my attached circuit diagram?
A quick off-topic question unworthy of its own post: I understand why each of the forbidden topics in the ToS for this forum exists, except one. What is the background on posting questions about non-transformer power supplies?
