Hi All,
I am a brand newbie to PICs as far as software goes, but I have about 30 years experience on the hardware side. I am having a devil of a time just getting an LED to blink with a 16F887. The LED is connected to port D bit 0; pin 19. I am trying to run blinkx.pbp from the melabs website; http://melabs.com/samples/LABX1-16F887/blinkx.htm. I have MicroCode Studio 4 with PicBasicPro v2.6 compiler. Here is the code:
ANSEL = %00000000
ANSELH= %00000000
LED var Portd.0
mainloop:
High LED
pause 500
low led
pause 500
goto mainloop
end
This gives syntax errors on lines 11 and 12 (ANSEL and ANSELH), and a bad data type error on line 13 (LED var Portd.0). I am really buffaloed by these errors. As I said, this example came right off of the microEngineering labs website. Any help would be appreciated.
Thanks in advance.
Regards,
mike
EDIT: Something wacky happened; I needed to uninstall MCS and PBP, and then reinstall them. Everything is now good.
Thanks.
Regards,
mike
ANSEL = %00000000
ANSELH= %00000000
LED var Portd.0
mainloop:
High LED
pause 500
low led
pause 500
goto mainloop
end
Thanks in advance.
Regards,
mike
Thanks.
Regards,
mike
