Can't find rare capacitor
Discussion in 'The Projects Forum' started by Guajiro, Jul 2, 2010.
  1. Guajiro
    Jul 2, 2010
    This project very specifically calls for a 1uF radial electrolytic 16V cap and I can't find one anywhere. Plenty of 50V, etc.
    My question is: can I use a 50V caps without affecting the performance? I have a suspicion that it calls for this style and size for a reason, since many of the other caps are more common, ceramic type.
    This is for a homemade earth resistivity logger, commonly used in the mining industry.
    If I can't use 50V, any suggestions on places to find a 1uF 16V rad elec. cap or an alternative?
  2. bountyhunter
    Sep 7, 2009
    2,498
    507
    Yes, you can substitute a higher voltage electrolytic.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You can almost always substitute a higher voltage rating capacitor.
    Be aware that a higher voltage rating may increase the ESR of the capacitor. If they recommended a specific mfgr & part number, find the datasheet for that capacitor, and match the specifications to a substitute.
  4. bountyhunter
    Sep 7, 2009
    2,498
    507
    Actually, a higher voltage ratig usually means a LOWER value of ESR, since going up in voltage for the same capacitance will mean a larger physical size and ESR will ROUGHLY correlate to physical size in a given family of capacitors.
