Can't find full name of MOV
Discussion in 'Electronics Resources' started by Onilll, Sep 11, 2012.
  1. Onilll
    Oct 25, 2010
    38
    Need to replace MOV's and can't get full name. MOV marked:
    PO
    Z575LNS OR LN5
    A3/G6-1 (not sure)
    Thank you.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
  3. panic mode
    Oct 10, 2011
    1,330
    305
    Metal Oxide Varistor
  4. BSomer
    Member
    Dec 28, 2011
    433
    106
    That is quite possibly a varistor made by CKE / HVCA. Their markings are very similar to the one you have. Here is a datasheet of some of their MOV's that come close to matching the number you have. However, these are all through hole packages where as yours is like a quick connect or formed leads.
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
    First you need to find a supplier with that size package, then look down their list and 575 is the voltage code.
  6. Duane P Wetick
    Apr 23, 2009
    408
    19
    This looks looks a typical Siemens unit (blue color). Look in their database.
    The size is a good indicator of its joule (energy) rating.
    Cheers, DPW [Everything has limitations...and I hate limitations]
