HiHello Sir... I did and made the schematics exactly as you have described.. Can you tell me how can I see the graph... I cannot seem to find it..
And by the way about those jumpers that has been used :: I ca see there is 5v jumper used with the battery and also with the other components but what about the jumper of ground in CD4017..??
And furthermore will the circuit not work in Interactive(DC) mode ? Since when i am clicking on Start it's showing Operating point not found.
Do check the attachments..
Set "Zero initial values" in Transient Menu
CD4017 - internal ground is connected to ground by default so no need to set it.
Colon at voltage measurement pin positions the trace in the graph
