cannot get output from gate driver fan7382 using optocoupler 6n137
Discussion in 'The Projects Forum' started by hidayah15, Mar 29, 2016.
  1. hidayah15
    Mar 13, 2016
    6
    im using a gate driver fan7382.
    stated in its fan 7382 datasheet Output drivers 350mA/650mA Sourcing/Sinking Current Driving Capability for Both Channels
    i am connecting output from the optocoupler 6n137 to the driver via a NPN transistor 2n2222
    the transistor collector output will be connected to the input driver.
    does that mean my collector current have to be 350mA/650mA to enable for my driver to have an output? because apparently i cannot get any output from my gate drive low out and high out
  2. shortbus
    Sep 30, 2009
    4,096
    1,692
    No, the driver output comes from the Vb input voltage. The Hin and Lin only need to be at a "logic" level. Why use the opto and transistor with this? The driver itself provides isolation (up to 600V, from the data sheet) between the driver and the high voltage side.
  3. hidayah15
    Mar 13, 2016
    6
    hi. thankyou for the input. i already managed to rectify my problem.
    much apreacited! :)
