Cannot connect to a pin in Eagle file.
Discussion in 'The Projects Forum' started by Dipali777, Oct 19, 2015.
  1. Dipali777
    Oct 19, 2015
    5
    Hi,actually I have done all connections properly in new package still I'm getting the same problem. Pins are not getting connected. So is there any other solution?Please reply
    Mod edit:
    Please don't hijack other member's post.
    This thread was split from below:
    Title : Cannot connect to a pin in Eagle.
    I have created a new library component in Eagle from scratch but cannot seem to connect to the pins.
    The symbol, package and device were created on 0.1" grid.
    Whether I use wire or net to connect to the pin makes no difference.
    When I move the device around the wires are not connected to the pin.
    What am I doing wrong?
    http://forum.allaboutcircuits.com/threads/cannot-connect-to-a-pin-in-eagle.72401/
  2. mcgyvr
    Oct 15, 2009
    4,791
    976
    post your part so someone with Eagle can open it and check it out..
  3. Dipali777
    Oct 19, 2015
    5
    I'm posting my schematic file. Please if anyone knows how to connect those ic pins then please reply.
  4. nerdegutta
    Dec 15, 2009
    2,568
    806
    HI.
    I ran the ERC. Electrical Rule Check. I got 7 errors, 142 warnings and 12 approved. Try to fix all errors and warnings. I would also advice you to check your Approved list. Go over it a few times.
    What are you designing?
  5. mcgyvr
    Oct 15, 2009
    4,791
    976
    I don't use Eagle (I have it just so I can remember how much I hate it) but shouldn't you post your library for that part to ensure its build correctly in the first place.
    post your dipali32.lbr file not the brd file
    Its clear that you cannot attach wires to the REN32SMD part.. Its not a valid symbol
  6. Dipali777
    Oct 19, 2015
    5
    This is the library file I have created. Please someone check and let me know.
  7. Dipali777
    Oct 19, 2015
    5
    Those errors are not related to the newly created device. Those errors are in my previous circuit.
  8. nerdegutta
    Dec 15, 2009
    2,568
    806
    But still, they are errors.
    I've looked at your lbr. You have not connected the pins to the pads.
    When you click on device, fourth icon on the toolbar, you get the attached picture on your screen. In the lover right corner, you must click connect, and assign the correct pin to the correct pad. Then save, open you schematic, remove the old part, and add the same part, but now with connections.
  9. Dipali777
    Oct 19, 2015
    5
    Hello guys,
    My problem is solved. I used the grid of 0.1 inch in symbol creation and schematic and its working now. Previously my grid was not same that is why it was happening.
