Candle Flickering High Power LEDs Transistor
Discussion in 'The Projects Forum' started by customlx, Apr 7, 2015.
  1. customlx
    Apr 7, 2015
    My question is: I'm trying to use a candle flicker LED with built-in chip to control 10 watts of high power LEDs through a transistor to obtain the same flicker rate.
    My base voltage is 12 VDC.
    Any recommendations for which transistor to use?
    Thanks!
  2. Dodgydave
    Jun 22, 2012
    5,150
    769
    need to see your circuit diagram,you may be able to use a mosfet, or bjt.
  3. customlx
    Apr 7, 2015
  4. wayneh
    Sep 9, 2010
    12,381
    3,236
  5. customlx
    Apr 7, 2015
    I will
