Can you see ground? I can't
Discussion in 'General Electronics Chat' started by Merlysys, Jan 20, 2014.
  1. Merlysys
    Nov 17, 2013
    23
    I bought these little boards but cannot see the ground connection, can you?
    There are 4 level shifters, input/output pins and Vcc for 5 and 3.3 I can see but where is the ground connection?
    The instructions say
    ...an example when Arduino is interfaced with an 3.3V device
    HV : high voltage level (connect to Arduino's 5V supply)
    LV : low voltage level (connect to Arduino's 3.3V supply)
    L1-L4 / H1-H4 : low and high level IO lines, connect 5V IO lines of Arduino to H1-H4 and IO lines of 3.3V device to L1-L4
    The listing is at http://www.ebay.ca/itm/181275880556
  2. R!f@@
    Apr 2, 2009
    8,786
    771
    I do not think you need a ground for this PCB
  3. 3v0
    Member
    Mar 26, 2009
    14
    Agreed. Connect the grounds external to this PCB.
