Can You prove this ??
Discussion in 'Homework Help' started by just-gal, May 25, 2009.
  1. just-gal
    May 25, 2009
    5
    hi there ,
    can you please help to prove these Boolean Algebra expression :
    (A+B) (A`+C) = AC+A`B
    and
    AB+A`C = (A+C)(A`+B)
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Take a moment to review the material on Boolean Algebra contained in the AAC ebook. I think you will find it a good supplement to any information in your course textbook.
    hgmjr
  3. steveb
    Jul 3, 2008
    2,433
    469
    Both problems are the same. So when you solve the first one, the second one is done.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Try laying out a truth table for each, this will constitute a proof.
  5. just-gal
    May 25, 2009
    5
    I know how to prove it using truth table but I need to prove it mathematically
    can you help me in this ?
  6. steveb
    Jul 3, 2008
    2,433
    469
    Do you know how to multiply out the left hand side of the first equation?
    If you multiply it out, you will have 4 terms. Two of these terms will match the right hand side. Can you figure out why the extra two terms are redundant and not necessary?
  7. Ratch
    Mar 20, 2007
    1,068
    just-gal,
    Yes, I can.
    Code ( (Unknown Language)):
    1.
    2. (A+B)(A'+C) = AC+A'B                     ; equation to be proved
    3. (A+B)(A'+C) = AA'+AC+A'B+BC = AC+A'B+BC  ; AA' = 0
    4. A(B+B')C+A'B)(C+C')+(A+A')BC             ; (X+X') = 1
    5. ABC+AB'C+A'BC+A'BC'+ABC+A'BC             ; expand expression
    6. ABC+AB'C+A'BC+A'BC'                      ; eliminate redundant terms
    7. AC(B+B')+A'B(C+C') = AC +A'B             ; factor out (X+X')
    8.
    Therefore the Boolean equation has been proven correct.
    AB+A'C is the dual of the left side of the original equation (A+B) (A'+C). and (A+C)(A'+B) is the dual of the right side of the original equation AC+A'B. Therefore, AB+A'C = (A+C)(A'+B) because the two expressions are duals of an Boolean equation that was proven correct.
    Ratch
  8. studiot
    Nov 9, 2007
    5,005
    515
    Does this list of standard Boolean results help?
    0.0 = 0
    0+0 = 0
    1.1 = 1
    1+1 = 1
    1.0 = 0
    1+0 = 1
    0'= 1
    1'= 0
    A+0 = A
    A+1 = 1
    A.0 = 0
    A.1 = A
    A+A =A
    A.A = A
    A+A' = 1
    A.A' = 0
    (A')' = A
    A+A.B = A
    A.(A+B) = A
    A.(A'+B) = A.B
    A+A'.B = A+B
    A+B.C = (A+B).(A+C)
    (A.B)'= A'+B'
    A'.B' = (A+B)'
  9. just-gal
    May 25, 2009
    5
    That's really helped me soo much , thank you soo much
  10. mango matto
    Member
    Jun 2, 2009
    13
    holy crap! I hope that one day I will understand a single word of this thread.
  11. Ratch
    Mar 20, 2007
    1,068
    mango matto,
    There are no advanced concepts covered in this thread. Everything is basic logic principles covered in any good textbook or course in digital logic. This knowledge is readily available from several sources. All you have to do is read and understand. If one source does not explain it to your satisfaction, try another.
    Ratch
