Long story short: Red Sparkling Dots on Plasma TV a.k.a Red Snow, kind of like "hell vision" may be caused by incorrect voltage if cause is not interference, cabling etc.
EDIT: SOLVED: Simply unplugging and plugging the DA5 cable [see attached picture] fixes the red snow problem.
After you open up the TV and read this: please click here
If you want to check if Vsus is 193 Volts,
You get the Service Manual. Locate the Test Point locations, please click here
So now if you put the RED part of the Digital Multimeter on the Test Point, where does black go... where is ground for the circuit?
1. Here is the Schematic, please click here
2. For actual Pic of Plasma TV Schematic, please click here
3. Is there ground next to TP15V, click here
4. Overall view, please click here
For additional info please click here. Thank you for your help.
