Hello all,
I'm trying to work out this: http://www.maplin.co.uk/Media/PDFs/fx88.pdf relay, they only had 2 left and I need both so i'm a bit hesitant of trying it with out checking im right first.
As far as i can tell when the coil activates it closes the switch between 1/14 and 7/8. And to activate the coil i connect 6 to 5v and 2 to ground?
And with the coil I can just pass 5v, I dont have to connect a resistor or capaster?
Thank you
Sol
Thank you
Sol
