I just need a name of the component shown in that image below. It's marked red . It was blown out, I must find an replacement component. Additional information, this is an power supply circuit board of "DPSN-96AP-1 A"
Btw. I found out that it's an Varistor "MDC Z151-03UL". If I understand correctly, it's used in a circuit to prevent against excessive voltage. It's made out of cermaic.
Now, I got to find a supplier for that component. I couldn't find any dealer around India, since I stuck at that place. If someone has better Idea finding close to my continent It would be very grateful.
Another idea - get one from a dead electronic appliance.
If the Varistor is the only part that is damaged, then the circuit should work fine without it, but it won't be protected from transients. If the circuit does not work right now, then go ahead and find the other damaged parts and order all the replacement parts at the same time.
