Can you design AM Radio with only "1" Active element?
Discussion in 'Wireless & RF Design' started by staryly, May 8, 2016.
  1. staryly
    May 8, 2016
    Hi!
    My goal is to build an AM radio for receiving in and around the 531kHz ~ 1602kHz frequency.
    BUT there are some limitations.
    1. Use only one Active Element (Diode, TR, IC...)
    2. The free availability of passive element (R, C, L...)
    3. Only one DC Power Supply.
    4. AM Radio must be able to receive more than 3 channels.
    so, I have designed basic AM Radio with envelope detector.
    but I want to improve performance of radio in terms of QoS(Quality of Service).
    How can I upgrade my radio?
  2. shteii01
    Feb 19, 2010
    3,514
    514
  3. recklessrog
    Member
    May 23, 2013
    346
    102
    Well, this is interesting, a little while ago, we were having discussions as to whether a diode is "active" and it depends on the application and your interpretation of "active" If you consider a diode as passive, then a crystal radio uses no active parts and vice versa.
    There used to be a little metal cased 3 pin (I think) a.m radio chip that only needed a tuned circuit, a couple of resistors, battery and earpiece. Someone on here will remember it better than me.
    Try googleing T.R.F a.m receiver.
    Just remembered the chip was an Zn414
  4. BR-549
    Sep 22, 2013
    2,184
    421
    recklessrog likes this.
  5. recklessrog
    Member
    May 23, 2013
    346
    102
    Yes that's the one I was thinking of, I wonder if they are still available. They were from the early seventies if I remember correctly..
  6. BR-549
    Sep 22, 2013
    2,184
    421
  7. RichardO
    May 4, 2013
    1,342
    429
    Maybe what you want is a reflex receiver.
    Note the single active device!
    Oh, drat it has a carborundum point contact diode. :D
