Can you build me a DC motor speed controller?
Discussion in 'The Projects Forum' started by diy549, Jul 9, 2009.
  1. diy549
    May 16, 2009
    11
    Hello all, I need a speed controller to control the motor speed of my two DC gear motors. I am trying to get a consistent speed under different loads. The motors are 12 volts and 6 amps and they are coupled together. Here is the link
    PM me a price and for more details.
  2. mik3
    Feb 4, 2008
    4,846
    63
    The link is missing.
  3. diy549
    May 16, 2009
    11
    fixed it..
  4. mik3
    Feb 4, 2008
    4,846
    63
    How the motors are coupled together and why?
  5. diy549
    May 16, 2009
    11
    With a rod, They need to move at the exact same speed.
  6. mik3
    Feb 4, 2008
    4,846
    63
    This is quite hard to achieve even with a closed loop control system. If one motor rotates a bit slowly it will load the other one and make more harm than good.
    Why you connect the motors on the same axis?
  7. diy549
    May 16, 2009
    11
    so far its working great. One motor was moving a tab bit slower, so I coupled them and now they are both moving a the same rate. They are only on for 30 seconds at a time, so I think it will be fine.
  8. mik3
    Feb 4, 2008
    4,846
    63
  9. Bernard
    Aug 7, 2008
    4,230
    412
    1. What do you have for a power supply?
    2. What speed desired, & tollerance?
    3. Is reverse needed?
