can we write C program for generating pulses???
Discussion in 'Embedded Systems and Microcontrollers' started by mala, Sep 14, 2009.
  1. mala
    Sep 14, 2009
    hii
    im having problem in understanding that is there really something exists like the generation of diffrent signals like square pulses , triangular, sine and comparison of two signals using c .....and then taking out the output using parellel port and using some PCI cards and feding them to some hardware circuit...
    is that really possible if yes please help me out how to start.....
    regards
    mala
  2. nanovate
    Distinguished Member
    May 7, 2007
    665
  3. russ_hensel
    Jan 11, 2009
    820
    47
    Yes.
    Get a pic, programmer, etc. perhaps a pickit. and learn to blink an led. Then make your question clearer and ask again.
    I would also consider the Arduino which seems easier and cheaper for beginners.
  4. Arm_n_Legs
    Mar 7, 2007
    183
    10
    You can use Lab View (National Instruments) to generate signal.
  5. ping
    Sep 16, 2009
    13
    So you want to use a PC as a function generator?
    I stand under correction but I think you could do some rough signal generation with your sound card output and the right software.
    Otherwise I have seen a USB audio frequency oscilloscope which also doubles up as a low frequency function generator, it will cost you a bit though.
