Can we solve this circuit
Discussion in 'Homework Help' started by Jony130, Feb 25, 2013.
  1. Jony130
    Thread Starter AAC Fanatic!
    Feb 17, 2009
    3,990
    1,115
    Here is a circuit that I can not solve.
    How we can use a nodal analysis to solve for Vx?
    (Vin - Vx)/R1 - ?? = 0
    I think that I have some kind of blackout today.
      File size:
      10.2 KB
      140
  2. WBahn
    Mar 31, 2012
    18,064
    4,904
    Is there a particular reason you want to use nodal analysis on this problem? Remember, nodal analysis is just KCL, so in general you want to avoid nodal analysis when there are voltage sources for which you will have to get currents for. Problems like this are much better dealt with using mesh current analysis.
    Pi Chi likes this.
  3. Jony130
    Feb 17, 2009
    3,990
    1,115
    I prefer nodal analysis. But yes you are right I can also use mesh current analysis.
    Vin - I*R1 - Vx = 0
    and
    Vx = Av*(Vp - Vx) ; I = (Vin - Vx)/R1
    so
    Vx = (Av*Vp)/(Av+1)
    THX
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    I don't see a simple equation for a node, since the node voltage is dependent on the node voltage (feedback).
    Ignoring the left side:
    Vx=10(2-Vx)
    Vx/10 = 2-Vx
    Vx=20-10Vx
    11Vx=20
    Vx=20/11
    Vx= 1.818 ±1V and resistor and direction of current.
  5. WBahn
    Mar 31, 2012
    18,064
    4,904
    If you only want Vx, that is quite trivial:
    Vx = Av(Vp-Vx)
    Vx = Vp[Av/(Av+1)]
    For Av=10 and Vp=2V, this is
    Vx = 2V(10/11) = 1.818V
    Done.
    I don't know where the ±1V is coming from???
  6. The Electrician
    Oct 9, 2007
    2,300
    335
    I find it easier to think about with this picture:
    Vin and the resistor are superfluous. I forgot to label Vx; it's the output.
  7. thatoneguy
    Feb 19, 2009
    6,357
    718
    Afterthought, adding the drop of R1 from the other source.
  8. WBahn
    Mar 31, 2012
    18,064
    4,904
    But, as I'm sure you've noted already, the other source and the resistor (as long as it is nonzero) have no effect on Vx.
  9. thatoneguy
    Feb 19, 2009
    6,357
    718
    I was trying to make a full node equation and it cancelled itself out, should have stopped there. :)
  10. WBahn
    Mar 31, 2012
    18,064
    4,904
    Yep, been there done that.
    The follow-up comment was for the OP's benefit in case he might still find it a bit confusing.
  11. Jony130
    Feb 17, 2009
    3,990
    1,115
    Hi, I don't know why but I'm unable to start new thread. So I decided to post my question here.
    I have this simple op amp based circuit
    And I try to find Vo voltage.
    So I write this equations for Vn node
    (Vout - Vn)/RL = Vn/R2 + ((Vn + Vin) - Vp)/Rin
    And for Vp node
    ((Vn + Vin) - Vp)/Rin = Vp/R1
    And after many attempts I finally find the solution
    Vo = Vin * ((R2 RL + R1 (R2 + RL)))/(R2 Rin)
    and
    Io = Vin/Rin (1 + R1/R2)
    But I want to ask you is there any easier way to find solution for this circuit?
    Maybe you know some trick that we can use here to speed up finding a solution?
      File size:
      7.9 KB
      68
  12. The Electrician
    Oct 9, 2007
    2,300
    335
    Convert Rin and Vin to a Norton equivalent current source of value Vin/Rin with Rin now connected between the plus and minus inputs of the input. Let V1 be the plus input, V2 be the minus input, and V3 be the opamp output, Vo.
    Then:
    I left the opamp open loop gain, A, as a finite quantity to deal with the case where an opamp isn't ideal; real opamps, in other words. If only the ideal case solution is wanted, the matrix can be modified slightly and the limit operation eliminated:
    You can't get much easier or speedier than that!
  13. Jony130
    Feb 17, 2009
    3,990
    1,115
    ThxThe Electrician, As always you show a matrix, but to be honest I'm not so confident with this type of a matrix. I always have problems with it. The only matrix that I can create is "Jacob Shekel matrix".
  14. LvW
    Jun 13, 2013
    674
    100
    I think, the wanted "trick" could be the following:
    The closed-loop gain of an idealized opamp (Aol infinite) with feedback can be expressed as Acl=Hf/Hr
    with Hf=(Vp-Vn)/Vin for Vout=0
    and Hr=(Vp-Vn)/Vout for Vin=0.
    Thus, the whole calculation is split into two separate steps which consists of two voltage divider ratios only.
    Example: Setting R2||RL=Rp we have
    Hf(Vout=0)=(Vp/Vin)-(Vn/Vin)=R1/(R1+Rin+Rp) - [-Rp/(R1+Rin+Rp)] .
  15. The Electrician
    Oct 9, 2007
    2,300
    335
    You show an expression for Hf(Vout=0) = R1/(R1+Rin+Rp) - [-Rp/(R1+Rin+Rp)]
    Next, an expression is needed for Hr(Vin=0) which will be similarly complicated, and the final result will be the quotient Hf/Hr.
    All this doesn't look much simpler (or speedier, as Jony130 asked for) than the matrix solution.
  16. LvW
    Jun 13, 2013
    674
    100
    OK - may be. No problem - this solution just came into my mind.
    As you know - each circuit can be analyzed following different approaches.
    Everybody has its own preference.
    Do YOU have a way which is simpler (speedier)?
    I think, only after collecting and comparing different methods for analyzing a particular circuit one can decide which way is the "best". And, most probably, different people will come to different preferences, don`t you think so?
  17. The Electrician
    Oct 9, 2007
    2,300
    335
    The matrix solution I gave seems to me to be the most simple. I did the second half of your method, calculating Hr(Vin=0), and it involves an expression similar in complexity to the first half, requiring a fair amount of algebra to get the final result.
    I used a computer to solve the matrix system which means not having to do the algebra by hand. But I also used the computer to manipulate the expressions involved in your method and it was still more involved. I had to type in the somewhat complicated Hf and Hr expressions before the computer could simplify them, which took more time and effort than typing in the matrix. The elements of the matrix are very simple, not at all complicated expressions.
    I don't think there is what I would call a really simple solution; it's a somewhat complicated circuit.
    The method a person has decided is the "best" might not be the most simple or speedy. A person might choose a method that leads to more algebra because they are familiar and practiced with it, thereby making fewer errors, and that would probably be their preference.
    Jony130 wanted a speedy method. The elements of the matrix are all very simple and quick to write without errors, which makes it a speedy method.
  18. LvW
    Jun 13, 2013
    674
    100
    Yes - this is exactly what I wanted to say.
    By the way - I didn`t intend to argue against your method.
    The title of this thread is "can we solve the circuit?"
    And - as an answer to the OP`s problem - I have mentioned one of different methods how to "solve the circuit" . That`s all. Perhaps it could help.
    LvW
  19. The Electrician
    Oct 9, 2007
    2,300
    335
    If you read what Jony130 said in post #11, he gave a new circuit in this thread because he was unable to start a new thread. The original title for the thread doesn't apply to the new circuit he gave in post #11; he was able to solve the circuit he gave in post #11, but he wanted an easier and speedier method.
    I didn't think you were arguing against my method, but Jony130 wasn't asking for just any method that could solve the circuit, even though that's the original title for the thread. The reason I was critical of your method is because it didn't seem to be easier and speedier, which is what Jony130 was asking for; perhaps you overlooked this request of his in post #11.
  20. t_n_k
    Mar 6, 2009
    5,448
    783
    This was the approach I used ....
