Can we generate 3.3V output with 3.3V input using Buck Regulator?
Discussion in 'General Electronics Chat' started by sharath_412, Dec 24, 2007.
  1. sharath_412
    Thread Starter Active Member
    May 7, 2007
    32
    Hi All,
    I was using a buck regulator to generate 2.8 Volts from 3.3 volts. Now i need 3.3 volts output. Can I use the same buck regulator with the same input voltage of 3.3 volts.
    regards
    sharath
  2. nanovate
    Distinguished Member
    May 7, 2007
    665
    Not really, any real switch will some small voltage drop across it. What is the reason you need a regulator? At those small voltage differentials you can often use an LDO (still has a small V drop from input to output).
  3. mrmeval
    Jun 30, 2006
    833
  4. Papabravo
    Feb 24, 2006
    10,338
    1,850
    A SEPIC converter has the possibility to have its input either above or below the output voltage. Is it right for you? Hard to say without knowing your requirements.
    A 3.3 Volt LDO will need at about 3.45 V on the input for 150 mV LDO. Your mileage may vary.
  5. sharath_412
    May 7, 2007
    32
    Thanks for the sugesions:
    Actually I am using Power Management unit which takes 3.3 volts. This PMU gives out other supplies. As mrmeval said I think we can use the 3.3 volts directly from the source.
    regards
    sharath
  6. n9352527
    Oct 14, 2005
    1,198
    Or a buck boost could do it.
  7. cooloo
    Sep 28, 2007
    Charge pump regulator can do it . Sometime we can't use 3.3V directly due to locked up on the digital circuit if for some reasons it falls out of V specs. The regulator can help it stay in 3.3V . Sorry for my English . Kinda to old to learn to write it correct .
