Hi all. Please can someone tell me if this will work. I know that I am essentially trying to build a UPS and that these are available ready made. I would like to know if my idea will work or if there is a flaw in my idea that I am missing. I have some of the bits I need already so I'd like to use them.
I want to provide an ac current from a deep cycle 12v battery via an inverter. I have a 300w inverter and I will only draw about 130w so that is ok.
I will build a switch using a relay to control the UPS on/off. My plan for this part is to connect the relay coil (SPDT I have is rated for dc on the coil and 220v ac on the load side so it should be fine) to a 12v off-the-shelf transformer and this will be used to hold the relay in an open position as long as the mains/grid power is on. The other side of the relay will be connected as a switch on the positive supply from my 12v deep cycle lead acid battery so if the mains power goes out the relay switches to the NC position completing the circuit from battery to inverter.
I will also connect a battery charger to the battery so while the mains electricity on on the battery charges. This will keep it topped up or if the electricity goes out it will start recharging the battery once it comes back on.
I think in my simple view this will work....charger, battery, control switch connedted to mains to control the UPS, and finally the inverter connected to my devices. By the way...the devices I will be running are a small aquarium heater and a water circulation pump.
I'd really like to hear from anyone who can say if my idea sounds feasible.
Thanks.
Thanks.
