Can this circuit to charge 1.5V battery with proper monitoring by LED?
Discussion in 'Homework Help' started by TYYang, Apr 3, 2015.
  1. TYYang
    Apr 3, 2015
    18
    and what should be the value for R2 1R5 ?
  2. #12
    Nov 30, 2010
    16,703
    7,341
    No. The minimum sense voltage for the TL431 is 2.5 volts.
  3. TYYang
    Apr 3, 2015
    18
    Thank you for advice.
    May i ask about how is the minimum sense voltage should have to charge the 1.5V Ni-mh ? and have any recommended component for me ?
  4. #12
    Nov 30, 2010
    16,703
    7,341
    An operational amplifier would work with a sense voltage less than 1.5 volts.
  5. Dodgydave
    Jun 22, 2012
    5,155
    772
  6. TYYang
    Apr 3, 2015
    18
    Erm..how can i connect with the op amp ? if i use LM324N
  7. #12
    Nov 30, 2010
    16,703
    7,341
    I can not seem to make myself redesign this circuit for you. It is the wrong circuit in the first place. It does not have the features necessary to protect NiMH batteries.
  8. Søren
    Sep 2, 2006
    472
    28
    If you want the cell to be protected against over voltage and over current, I could change a couple of resistor values to make the below SLA charger useable for NiMH-cells.
    Get the full page at:
    http://www.sentex.ca/~mec1995/circ/SLAC.htm
    TYYang likes this.
  9. TYYang
    Apr 3, 2015
    18
    Thanks, It seem good,but my project need have 2 color LED monitoring the battery. Do you have any other suggestion ?
  10. TYYang
    Apr 3, 2015
    18
    How u all think about this circuit can function well ?
  11. WBahn
    Mar 31, 2012
    18,087
    4,917
    Your project?
    Is this a school project of some kind?
    The text in your Post #10 reads like gibberish. It's probably just an English as Second Language issue, but you are going to need to really work at making that text more readable before we can do much.
  12. TYYang
    Apr 3, 2015
    18
    Actually it is one of my school homework.
    I need to design an solar panel battery charger circuit. It is with the function of LED monitoring in state charging or full.
  13. Søren
    Sep 2, 2006
    472
    28
    The post #10 sure makes me think of a famous quote from Pulp Fiction :D
    Well, it being homework changes the game a bit, as you are the one supposed to make it!
    So, I'll stick to give you some pointers.
    Another game changer is that it is supplied from a solar panel, as this means that you have to avoid losses as much as possible.
    The circuit in #10 is an odd X-mas tree of inferior design, better start from the bottom and make a block diagram of what you think it must contain. Then post that here for review.
    You might wanna take a look at the datasheets for LM393 (dual comparator) and LM339 (quad comparator), as they may be quite helpfull in solving the task.
    If it's within the boundaries of your assignment,, you might consider a fairly simple so-called flash-charger, which has a single LED on when charging and when it reaches full, it will pause until the terminal voltage of the cell has dropped a little and then charge to the limit again etc. - the flashes will become shorter, as the cell is topped up after the initial charge.
    TYYang likes this.
