I'm modifying an existing piece of hardware and can't redo the power supply. I need to add a couple additional 12v sources and the only way is to use a voltage doubler since the power supply is 9VAC. I'm wondering what are the limitations of voltage doubling? Can I just buy an AC adapter with double the current rating that I need (9V/400mA in this case)? Is there anything I need to take into account regarding the filter capacitors?
I'd really just like to know if this power supply can handle 200mA of current draw? At some point would the current draw exceed the filter capacitors ability to regulate?
