Can someone write me a program in ASM ?? (digital thermometer, LM35)
Discussion in 'Embedded Systems and Microcontrollers' started by Baron1, Dec 28, 2009.
  1. Baron1
    Nov 18, 2009
    hi, i need some urgent help. can someone write the program for this circuit in Assembly for me if i am not asking too much. i need to submit a project report by tomorrow and was quite busy bit other stuff. All help appreciated. thanks.
  2. Boo
    Member
    Oct 27, 2009
    40
  3. Boo
    Member
    Oct 27, 2009
    40
    I don't know why I can't upload things but here I'll put the code up on my website... give me a few mins....
  4. Boo
    Member
    Oct 27, 2009
    40
  5. Baron1
    Nov 18, 2009
    thanks. il give this a try. Any other suggestions??
  6. Boo
    Member
    Oct 27, 2009
    40
    By the way, using a comparator is much more difficult.
  7. steinar96
    Apr 18, 2009
    239
    Unless someone has got the code already. I doubt someone will code the entire thing for you since programming in ASM can be quite tedious. I think this also falls under "homework" and current policies dictate that we shouldn't do homework for people but help them.
    So if you attempt to program it yourself and post things when you are in trouble i'm sure you'll get assistance right away :)
  8. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Too busy to do ones homework assignment...
  9. spinnaker
    Oct 29, 2009
    5,076
    1,176
    Hilarious!
    :D:D:D:p
  10. Papabravo
    Feb 24, 2006
    10,340
    1,850
    If you want a working program, what you ask is not even remotely possible given the lack of hardware to test it on. If I had the hardware in my hand and at least a week then maybe. Prior planning would have prevented this disaster.
  11. Tahmid
    Jul 2, 2008
    344
    27
    If I tweak the hardware a little, I can write you one such LM35 thermometer program, but in mikroBasic, writing assembly code from scratch is tedious work!
  12. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    I doubt his instructor wants it done in BASIC :) besides it's probably too late as a full day has already passed.
  13. Papabravo
    Feb 24, 2006
    10,340
    1,850
    My hat is off to you Bill, for your intuitive grasp of the obvious!:)
    Rock on & well done!
  14. dor
    Feb 20, 2009
    62
    hm.. why not disassembling a compiled C code?
  15. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Good luck commenting and explaining disassembled C code. It won't look anything like normal assembly code.
  16. Papabravo
    Feb 24, 2006
    10,340
    1,850
    A perfect learning experience for a noob!:)
  17. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Indeed. Don Lancaster learned about programming from spending a summer disassembling Applesoft Basic. Time and interest.
  18. Papabravo
    Feb 24, 2006
    10,340
    1,850
  19. dor
    Feb 20, 2009
    62
    Sorry for the obscurity.
    I meant disassembling a binary file, which source code is written in C.
    You wrote "disassembled C code", and I wrote "disassembling a compiled C code".
    The "compiled" is omitted in your reference, which makes the whole difference, I assume...
  20. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I think it may be a distinction without much of a difference. The only real advantage my be some regularity of stucture, since goto statments, although allowed, are mercifully rare.
