Can someone tell me how this switch works?
Discussion in 'General Electronics Chat' started by hunterage2000, Nov 19, 2012.
  1. hunterage2000
    Thread Starter Active Member
    May 2, 2010
    402
  2. tshuck
    Oct 18, 2012
    3,531
    675
    According to the datasheet, in order to use this as a simple ON-OF switch, you''d need to connect to pins 2 and 1... pin 3 appears to be connected to pin 2 through a 100kΩ resistor and a light.....
  3. KJ6EAD
    Apr 30, 2011
    1,426
    364
    1. Line in.
    2. Load.
    3. Neutral.
    The neutral connection to pin 3 is needed to complete the circuit to power the neon illumination.
  4. hunterage2000
    May 2, 2010
    402
    Yeah tried it but nothing happens, The switch may be dodgy, Im not sure but I just used 5VDC.
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    Many high current switches have silver contacts. Silver corrodes and will not pass a small voltage or small current because it needs the arc from a high voltage and current to burn away the corrosion.
    I always used gold contacts on switches and relays for low voltage and low current switching. Gold does not corrode. The thin gold plating costs the same as thick silver plating.
  6. gerty
    Aug 30, 2007
    1,154
    304
    If you are referring to the light not working,it won't, it looks like a neon bulb which requires about 70 volts and up.
  7. hunterage2000
    May 2, 2010
    402
    So can an alternative switch be recommended that uses low DC voltages around 5-10V?
  8. tshuck
    Oct 18, 2012
    3,531
    675
    what is you current requirement?
  9. ScottWang
    Aug 23, 2012
    4,933
    777
    The switch using in AC And DC circuit maybe as below:
  10. gerty
    Aug 30, 2007
    1,154
    304
    Is the switch turning the 'load' on but the light not working?
    How much current does the load draw? or what is the load?
    Do you have access to a meter?
    Answer these and we might could help you
  11. Audioguru
    Dec 20, 2007
    9,411
    896
    You need a switch that has a low voltage LED, not this switch that has a high voltage neon bulb.
