Can someone show me how to set up an 8 pin relay?
Discussion in 'The Projects Forum' started by Gibling, Jun 12, 2009.
  1. Gibling
    May 28, 2009
    11
    Ok so I'm a complete noob at relays, and well, circuits too. So would someone be able to expain in the most uncomplicated, simple minded way possible how to set up an 8 pin octal relay. This one to be exact.
    Basically, I have a DC power source, and a DC motor. All I want is for the motor to turn one direction, then when the relay time is up, for the current to reverse and the motor to turn in the other direction. As it's a repeating relay, I want this to continue until I turn it off.
    Would someone be able to draw up which wires go where on the actual 8 pin socket? Or if there's anything I need to add for this to work could you draw that too?
    Thanks for your help!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You need the relay socket that is pictured on the page that comes up. The relay will not work without it.
    You can go to the manufacturer's site and get the drawing for the relay, or just wait until it arrives - there is a pin diagram on the case.
    The NC contacts are closed when the relay is unpowered, the NO contacts close when the relay is powered. To reverse the motor, you reverse the voltage to it.
    Your motor may overheat and die from this treatment. It is best to let the motor stop rotating befre reversing it.
  3. KMoffett
    Dec 19, 2007
    2,584
    234
    Electrically, the attached is how you could hook it up. But, like beenthere said this is hard in a motor. Reversing a running motor puts a lot of stress on it mechanically and electrically.
    ken
  4. Bernard
    Aug 7, 2008
    4,235
    414
    Something like this? Do you have limit switches to prevent a clashing of gears when relay says GO and mechanical limits says STOP?
  5. KMoffett
    Dec 19, 2007
    2,584
    234
    Bernard,
    The pin you labeled "7" on the common terminal on the lower set of contacts should be "8".
    Ken
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Just for reference, the original thread is here: http://forum.allaboutcircuits.com/showthread.php?t=24025
    Gibling, you need more than a simple timed relay for your application.
    You must have limit switches to detect when the container is at the limits of it's travels.
    You can use Hall-effect sensors, but they can fail. A normally-closed switch that breaks the circuit when activated would provide a degree of safety to prevent damage when failure occurs.
    You must keep in mind that everything will eventually break/wear out/fail, and to build things so that when failures occur, nothing bad will happen.
    It will prove impossible to simply set a time on a relay, and have the barrel rotate horizontally/vertically to arrive in the exact same position every time.
    The best use for the timer relay would be to provide a "coast-down" delay for the motor when a limit is reached.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    And the pin labeled "2" on the common terminal on the upper set of contacts should be "1".
  8. Gibling
    May 28, 2009
    11
    Ok thanks guys. I'll mention all the technical/safety details to my boss, and hopefully he'll take them into consideration and/or get a professional to build what we need. This has turned out to be much more complicated that I imagined. Mad props to y'alls!
  9. Bernard
    Aug 7, 2008
    4,235
    414
    A little late, but thanks Sgt. & Ken for covering my 6. Should have had my coffee first.
  10. Kauhu
    Member
    Mar 7, 2009
    10
    Indeed, you must stop the motor before reversing it. Otherwise it will burn. Shame I don't have old school assignments saved anymore, I did this same thing with couple timed relays. It also had a safety switch so that the direction couldn't reverse if the motor was running.
