I have always done things correctly so I have never blown up an IC, transistor or capacitor and not even an LED.Some would say that blowing IC, transistors and capacitors is part of the learning process.
I have yet to blow LEDs on accident.I have always done things correctly so I have never blown up an IC, transistor or capacitor and not even an LED.
So maybe I learned nuttin.
That's not what he said. He said that blowing components is part of the learning process. If you fry LEDs, it helps you learn. That doesn't mean that if you don't fry them, you don't learn. That's like saying "Only the good die young", and then looking at someone who died when they were old and saying "they must not have been good". That's not what the saying means.I have always done things correctly so I have never blown up an IC, transistor or capacitor and not even an LED.
I was just referring to this:I have always done things correctly so I have never blown up an IC, transistor or capacitor and not even an LED.
Excuse me? I'm still here. Some how I've managed to blow a second 555. I looked over my circuit three times before I used any power.. I really have a bad grip on this all.hmmm. so it seems... I agree with you Adjuster
Did we scare OP away?
Post a clear, close photo or two of your breadboard; someone may be able to spot the problem.Excuse me? I'm still here. Some how I've managed to blow a second 555. I looked over my circuit three times before I used any power.. I really have a bad grip on this all.
There is already a 10k Ohm resistor going from the switch to the positive.. That 10k resistor that is label as R1 is to discharge the capacitor to prevent the circuit from firing for longer than the determined pulse.Post a clear, close photo or two of your breadboard; someone may be able to spot the problem.
ETA: If your breadboard is built like the schematic in post 5, the 10k resistor you have labeled as R1 is in the wrong place. It should go from the switch to +12, not from the switch to pin 2.
Care to share?I know what I did wrong with my circuit now, I just need to go get another chip.
I put my positive as the ground and my negative as the source.Care to share?
I've still got a ways to go yet. I may make a PCB for the base circuit when I get that part finished. However, I still need to work on making the trigger work for the timer circuit. Then I have to solve my LED problem.Oh... That explains a bit. Would be nice to see the complete circuit/pcb when it is finished.
Good luck.
The 10k resistor you have labeled as R6 is a pull-up resistor to hold the trigger input high until it receives a negative going pulse from the switch. The combination of the resistor you have labeled as R1 and C1 is a conditioning circuit, and R1 is supposed to go to +12. Here is Bill Marsden's post that contains a schematic to that effect. http://forum.allaboutcircuits.com/showthread.php?t=14018There is already a 10k Ohm resistor going from the switch to the positive.. That 10k resistor that is label as R1 is to discharge the capacitor to prevent the circuit from firing for longer than the determined pulse.
Is this U'r new Year Resolution... .I put my positive as the ground and my negative as the source.
It's called people need to use one system. One of the schematics I looked at for my 555 used electron flow and didn't specify that while the other used conventional.Is this U'r new Year Resolution... .
Advice Uri Neighbors to start packing
A rocket Engineer is living in the Premises.
by Aaron Carman
by Jake Hertz
by Jake Hertz
by Aaron Carman
