Can someone help me solving the circuit attached?
Discussion in 'Homework Help' started by i_nour, Nov 9, 2015.
  1. i_nour
    Nov 9, 2015
    29
  2. Jony130
    Feb 17, 2009
    3,991
    1,116
    Can we see your attempt first ??
    Tip - don't forget to connect the GND together
  3. i_nour
    Nov 9, 2015
    29
    I tried to solve it, but then I realized that Vout shouldn't be 100. I get confused.
    also I didn't know how to connect GND together
  4. Jony130
    Feb 17, 2009
    3,991
    1,116
    Try again but this time with this redrawn circuit by me:
    i_nour likes this.
  5. i_nour
    Nov 9, 2015
    29
    It worked ! thank you
  6. Jony130
    Feb 17, 2009
    3,991
    1,116
    It wasn't that hard after all ?
  7. i_nour
    Nov 9, 2015
    29
    yeah
    well, can I redraw this circuit in that way?
  8. Jony130
    Feb 17, 2009
    3,991
    1,116
    Yes you can, but this circuit is tricky.
  9. i_nour
    Nov 9, 2015
    29
    I found that the sum of the branched currents is bigger than the primary current..why? how to solve it?
  10. Jony130
    Feb 17, 2009
    3,991
    1,116
    Because in this case only one of the two diodes can conduct, and your job is to find out which one it is (based on circuit analysis).
    i_nour likes this.
  11. i_nour
    Nov 9, 2015
    29
    I think the solitary one is off, and the other is on
    you helped me, thank you
  12. Jony130
    Feb 17, 2009
    3,991
    1,116
    Do you have any proof for that ??
  13. i_nour
    Nov 9, 2015
    29
    The positive terminal of the first battery is connected to the anode while the positive terminal of the second battery is connected to the cathode and because the batteries are equivalent, they canceled out each other. Is it right?
  14. Jony130
    Feb 17, 2009
    3,991
    1,116
