Can someone figure these out?
Discussion in 'Homework Help' started by HVACIV, Jul 4, 2009.
  1. HVACIV
    Jul 4, 2009
    As the frequency of an AC circuit is increased, a inductor looks more like a/an
    A) short
    B) high impedance load
    C) open
    D) high reactance load
    Two 10 ohms resistors in parallel across a 600 Vdc source would consume a total of :
    A) 3.6 kW
    B) 72 KW
    C) 360 W
    D) 7.2 kW
    If the voltage of a circuit is fixed and the temperature of the air surrounding the circuit begins to increase:
    A) power consumption increases
    B)current decreases
    C) power consumption holds steady
    D) current holds steady
  2. natishalom
    Nov 3, 2008
    hi.
    the answer to the second question is 72KW.
  3. aditya_chee
    Jul 4, 2009
    Hi
    If frequency (f) is incresed, the inductive reactance XL = 2(pi)fL increases. Reactance which is supposed to be the ressistacne of the inductance poses more resistance to the current flowing into it. As u increase the frequnecy, its literally gets verry less current and therefore acts as an open circuit
    Hope this helps !!
  4. R!f@@
    Apr 2, 2009
    8,792
    771
    I is D
    2 is B
    3 is A
    Still Circumstances should be accounted for though
    Rifaa
  5. Beduin
    Member
    May 20, 2009
    16
    Hi there :)
    Care to explane # 3, please?
  6. R!f@@
    Apr 2, 2009
    8,792
    771
    In a closed enclosure with a powered circuit dissipating heat and if there is no air flow, the ambient temperature will keep on rising to the point where passive components melt ( meaning internal resistance drops causing the increase in power dissipation ), and if a semiconductor is there, the heat will cause thermal runaway which results in increasing power dissipation.
    Atleast this is what happened to my sealed circuits, if the surrounding cannot vent heat
    Rifaa
