The control always a 12 battery feed then there is a 12 volt Wake up wire connected that I will connect to an iginition circuit. Here is the wiring diargram for the harness. It's the module labeled Module-Selective Catalytc Reduction this diagram only show the input connector
mcgyver I am not trying to be difficult but pretty much yes. The pump is a brushless DC motor so it needs to be 3 phase. So no a simple relay will not work. I don't know how to make the gate open and close when they are suppose to. Like i said the heater function would also be nice but not required. If i need to call you on the phone to explain this better i will.
This thread is a violation of the AAC forum rules, Chapter 6, on automotive modifications, as seen here: http://www.allaboutcircuits.com/l_tos.html
Therefore, this thread will be closed.
Please understand the reasons behind this action and bear no grudge.
Feel free to tread on the rest of the forums.
