Can somebody help me identify this transformer
Discussion in 'General Electronics Chat' started by kapooski2012, Jan 8, 2016.
  1. kapooski2012
    Oct 17, 2012
    7
    I need help to identify this item. I think it is a line conditioner but I am known to be wrong. picture2.jpg picture3.jpg picture4.jpg picture2.jpg picture3.jpg picture4.jpg
  2. #12
    Nov 30, 2010
    16,704
    7,354
    It's an isolation transformer with all the information you could possibly need printed on it.
    MaxHeadRoom likes this.
  3. kapooski2012
    Oct 17, 2012
    7
    It would be ideal if I wanted to build an a/c to d/c variable power supply, yes? I also have a large variac
  4. #12
    Nov 30, 2010
    16,704
    7,354
    If you need 30 or 60 VAC RMS at 1.2 amps maximum.
  5. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    IOW it is a 156Va transformer.
    Max.
  6. #12
    Nov 30, 2010
    16,704
    7,354
    It may be 156 VA rated, but only for its original purpose. If you try to input at the 480 volt winding and output at the 120 volt winding to achieve 30 volts, you are limited by the diameter of the wire which is calculated to deliver 156 VA at 120 volts. The smallest wire in the transformer will be the limiting factor, and I think it is the 480 volt input. That one is built for 0.32 amps and, if you apply 120 volts there, in order to get a 30 volt output, the limit is 38.4 VA.
  7. kapooski2012
    Oct 17, 2012
    7
    I have no intention what so ever to use 480 volt. I would be using what's available in my garage/small workshop 120 volts. I very limited knowledge of electronics. The transformer came form a plant that closed a few years ago, along with the variac. I've tinkered with small stuff, like using a computer power supply to make a 12v power supply to use in a electrolysis project (removing rust from cast iron pan). So with this isolation transformer and my 120 v variac, I would need a few more parts to fabricate a d/c power supply that would have...an output of how much?
  8. kapooski2012
    Oct 17, 2012
    7
    Here's the link to the transformer if it helps any BTW its model CX140
  9. BR-549
    Sep 22, 2013
    2,181
    419
  10. kapooski2012
    Oct 17, 2012
    7
    So I can't use it as isolation transformer. So I understand this correctly , the only thing its good for is providing somewhat clean power to a 3 wire start/stop, nothing else? What else could I use it for fun in my workshop. Almost retired and need to do something with the stuff I have, caps, a couple of breadboards, a bunch of resistors....can't forget two auto transformers.
  11. BR-549
    Sep 22, 2013
    2,181
    419
    Heck yes,....you can use it for anything at those voltages and currents. Make a nice bench supply.
  12. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    It is an isolation transformer, usually termed a control transformer, use for anything you want within the VA capability.
    Max.
  13. GopherT
    Nov 23, 2012
    6,315
    4,040
    If ( when) you get an oscope, or other test equipment can be powered through this isolation transformer so you can isolate it from any mains powered project you work on. It makes everything a bit safer for you and a lot safer for your scope.
  14. kapooski2012
    Oct 17, 2012
    7
