1. ahmed hammad
    Jul 4, 2010
    9
    can i use c# for programming microcontroller ?
    and it's better then using assembly language or not
  2. ahmed hammad
    Jul 4, 2010
    9
    plz link of programme c #
    and i will self learning what is the best site can i use it ?
    thanks
  3. debjit625
    Apr 17, 2010
    790
    186
    No and Yes ,C# is created by Microsoft for their Framework named .Net and C# programs will run only in platforms where .Net is running i.e.. dotnet rumtime.Like windows mobile also use processors and these mobiles have .Net Runtime so C#(.Net) programs will run on a windows mobile.
    But in general their is no way to use C# in MCU like of PIC,ATMEL,MOTO.. etc.But at the root we all are using assembly to instruct the MCU for example when we write a C code then compile it ,the compiler converts the logic to assembly.
    Use C to programe MCU, its still the best system programming language.
    Good Luck
  4. retched
    Dec 5, 2009
    5,201
    313
    If you can find a C# compiler for your microcontroller, then absolutely.
    I have never seen one.
    Microsoft has an embedded version of windows for uCs.. So they may have a C# compiler around there.
    If they do, It most likely costs 1000s of dollars
  5. Rush
    Oct 12, 2009
