The 330Ω will work OK if you use 9VDC. The power supply is the first thing to commit to when designing something like this. You can use 6 D cells to make 9V, but the two extra batteries are to compensate for the resistors. You can also use several 9V in parallel to make it last longer.I spent some time (and money) on ebay prior to finding AAC.com. I ordered the following LEDs, which should be delivered sometime next week.
Art
5mm Flat Top White LED With Wide Angle
Emitted Colour : White
Lens Color : Water Clear
Forward Voltage (V) : 3.0~3.2
Forward Current (mA):20
Viewing Angle: 120-140 degree.
Luminous Intensity: 18000mcd
I also purchased 100 resistors (5%, 1/4 watt, 330 ohm)
While looking around on futurlec.com I found 85 different ohm options for the 1/4 watt, 5% resistors. I have no idea what I will need going forward, so I'm tempted to just purchase 50 of each. I assume that would be enough for a while and only cost about $42.50 + shipping (based on .01 each).
Please let me know if you have any suggestions or recommendations. I am not set on purchasing through futurlec.com, but .01 each is a great price.
Thank you again for your help.
by Aaron Carman
by Jake Hertz
by Duane Benson
