Can I used the power supply is large voltage to prevent the drop voltage when loaded?
Discussion in 'Embedded Systems and Microcontrollers' started by anhnha, Apr 29, 2012.
  1. anhnha
    Thread Starter Active Member
    Apr 19, 2012
    776
    48
    Hi there,
    In my circuit the standard is 5V power supply.But there is a problem that when i used 5V as standard then when the load is connected the voltage is droped to 3.78V.Can I use the higher power supply to offset this?
  2. MrChips
    Oct 2, 2009
    12,648
    3,458
    You need to examine the requirements of the load. How much current at 5v does it require? Then match the power supply with the load. Get a power supply that delivers about 3v more than what is required. In this case use a power supply that is rated at 8 or 9v at the maximum current required.
    To help even further, you can use a low drop-out regulator.
    Edit: I assume that there is already a 5v regulator on board.
  3. praondevou
    Jul 9, 2011
    2,936
    489
    Just make sure you don't use the power supply with the higher voltage on a lighter load specified also for 5V. The power supply's voltage drop will be less with a lighter load, possibly damaging the load.
    What you want to do works fine with a constant load.
