can I use vs+ and vs_ of max232 as power supply
Discussion in 'General Electronics Chat' started by wrenwood, May 12, 2008.
  1. wrenwood
    Apr 25, 2008
    for chips likes opamps. just wondering
    many thanks!
  2. Caveman
    Apr 15, 2008
    471
    If you have low current, yes. Unfortunately, they don't describe it very well, but it should be possible. Try it out. Just a note though. Sometimes, opamps pull a little more current in certain areas of operation. So you may have trouble getting it to charge up even if it works if it is connected after being fully charged.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    That depends upon what's powering the MAX232, which is (if I remember correctly) an RS-232 type interface IC.
    If the MAX232 is in use, you will likely find that the power pins have a good deal of noise on them, which is usually not a good thing for opamp circuits - they may still work, just not like you expected them to.
    If you want a decent and cheap bench supply, salvage an ATX form-factor power supply from a junked PC and build one from it. Google: "ATX Bench Supply" for lots of plans.
  4. wrenwood
    Apr 25, 2008
    thanks. I tried to hook them up to an instrumentation amps INA126 and measured output from a thermocouple, it worked fine. but it doesn't work with a thermocouple calibarator.
  5. wrenwood
    Apr 25, 2008
    sgtwookie
    thx. I actually made one of this ATX kits
