Hi All
I've just acquired a universal AC/DC adapter that plugs into the wall and outputs 3, 4.5, 6, 7.5, 9 and 12V at 500mA. Can I use this directly into a simple circuit like a 40106 oscillator (from Nicolas Collins' book)? I have the oscillator breadboarded, going into a 1W simple amp (little kit I bought) and then going into a mixer and finally into a big Yamaha HiFi amp. I've been using a 9V battery and it sounds great. Will the adapter work as well? I've seen videos and web pages describing another small circuit that needs to be used between the adapter and the circuit:
http://www.solorb.com/elect/musiccirc/9vbatelim/
I don't think this applies as I can choose the voltage on the adapter. Also my understanding of Amperes is a bit loose but I think that 500mA is it's capacity as opposed to it's output so as long as my circuit doesn't exceed 500mA I'm ok. Is this right? Will my circuit be likely to exceed that limit?
Scott
Scott
