This part:
http://pdf1.alldatasheet.com/datasheet-pdf/view/125951/IXYS/IXSK50N60AU1.html
I'm building a 100 Volt DC power supply but I'm not sure what to use as a high voltage regulator and I was thinking I could use the part in the link I have above. I want to minimize voltage cut off as much as possible.
Also as a side question, is it fine if I use the standard values for regulating capacitors? (10 uf at input of regulator, 10 uf & 0.1 uf at output of regulator)
Thanks.
Thanks.
