can i use ir2130 for a 3phase rectifier with igbt
Discussion in 'General Electronics Chat' started by coolka, Aug 3, 2009.
  1. coolka
    Aug 3, 2009
    hi alls
    i want to use ir2130 for a 3phase rectifier with Igbt(15 volt)
    is it possible?
    if yes , whats the schema for use? is it like a 3 phase inverter ?
    if no , give me a driver to use for a commandable rectifier?
    thanks
  2. mik3
    Feb 4, 2008
    4,846
    63
    DO mean that the MOS will drive the IGBT?
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Those are DC devices. A reverse bias will destroy them. The device for a controlled rectifier is the SCR.
  4. coolka
    Aug 3, 2009
    its not the problem of the software, because the commande is the same with the inverter
    i have problem with ir2130 , the pulses gate is not well it have negative value ie: the signal go for negatif to positive
    supposition:the problem in vs1,2,3 ,whats the correct shema of ir2130 for rectifier? the value of capa?and resistances?,,,
    thanks
