Can I use an Op-Amp for an EEG setup?
Discussion in 'General Electronics Chat' started by Raxnos, May 23, 2015.
  1. Raxnos
    May 21, 2015
    18
    Hi People, quick question: could I use small Op-Amps to boost the Voltage output of my electrodes for my EEG setup? By that I mean, could I attach a small IC Op-Amp to an Electrode and have that boost the voltage instead of using some fancy, expensive multi-channeled amplifier? So, I would have an individual IC Op-Amp per electrode. Thanks!
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  3. Raxnos
    May 21, 2015
    18
    Ok thanks! Can you get cheap-ish IC instrumentation amplifiers?
  4. Alec_t
    Sep 17, 2013
    5,979
    1,138
    Just visit any major electronics distributor's site and search for 'instrumentation amplifier'. You will find lots to choose from (depending on what you consider 'cheap' ;)).
  5. Raxnos
    May 21, 2015
    18
    Great thanks! What sort of specs should I be looking for? Considering I need as accurate EEG data as possible. Thanks!
  6. ranch vermin
    Member
    May 20, 2015
    85
    Just a guess from me, as I come from a software background ->
    its the really the 'microphone' which is the only important bit to the hardware, if your starting from the same raw signal as them, digital filters (even tho making it a fully brittle data process -especially if you used a FFT, thats the brittlest you can get!!!) should be able to outperform analogue filters, and do the whole thing with programming - if you wanted to compete as a performance product, and the cheapness that goes with software.
    I saw an eeg setup and it was just a simple band pass filter, what if theres something better you can do than that easily...
  7. paulktreg
    Distinguished Member
    Jun 2, 2008
    625
    125
    I recall the INA126 is used for EEG aquisition.
    Don't know whether that helps you?
  8. Raxnos
    May 21, 2015
    18
    What do you mean?
  9. Raxnos
    May 21, 2015
    18
    That's pretty helpful thanks! Do you know if the 2-channeled version (INA2126) has any differences other than the fact it's 2-channeled? Also, I like your ECG profile picture :)
  10. MrChips
    Oct 2, 2009
    12,642
    3,457
    As a general rule when working with sensitive signals I stay away from multiple amps in a package, at least at the first amplification stage.
  11. Alec_t
    Sep 17, 2013
    5,979
    1,138
    That doesn't equate to 'cheap' :D. I'd be looking for an amp with minimum input offset and temperature-drift (but I've not worked with instrumentation amps; other members here may know of more important features?).
  12. MrChips
    Oct 2, 2009
    12,642
    3,457
    The most important spec for an EEG instrument amp would be the CMRR, Common Mode Rejection Ratio.
    You have two long leads coming from the patient to the inputs of the in-amp. There will be a large common mode signal which you really want to reject.
  13. ranch vermin
    Member
    May 20, 2015
    85
    they put homomorphic filtering on xrays and it brings them out better, theres got to be some "contrasting noise reduction" equivilent for a 1d signal.
  14. Raxnos
    May 21, 2015
    18
    So the longer the wire from the electrode the more noise created by it?
  15. AnalogKid
    Aug 1, 2013
    4,704
    1,300
    Yes, long wires act as noise receiving antennae, but it is nothing that hasn't been working for a few decades. Two things about EEG signal processing. 1. It's been around for almost 100 years, although the first 50 really didn't count, so the requirements are very well known; there are no magical secrets to success. 2nd, while it is very well known, that does not equate to cheap. The signals are not very fast, but they are tiny and need careful attention. To get signals as reliable as those in pro equipment, you have to do what the pros do: a high-quality instrumentation amp with some form of DC stabilization, an adjustable bandpass filter, low noise power supplies, above-average power supply decoupling at each chip, and careful attention to pc board layout techniques.
    Patient-contact electronic devices have very large liability insurance costs that contribute to their high price, so making EEG amps is much cheaper than buying them as long as you accept the risks. But there is more to it than a few opamps on some perf board. What bandwidth are you interested in?
    ak
  16. Raxnos
    May 21, 2015
    18
    Mainly Alpha thanks. Also, can you recommend any amps to purchase or any circuit designs for amps?
  17. AnalogKid
    Aug 1, 2013
    4,704
    1,300
    I put "'eeg preamp schematic' and 'eeg amplifier circuit' (without quotes) into Yahoo and got a bunch.
    Let's be clear here - patient contact electronic circuits are dangerous, but as long as they're not in a car...
    ak
    shortbus likes this.
  18. ranch vermin
    Member
    May 20, 2015
    85
    I always having dreams about doing armed robbery eeg'ing to your robot body, and making the next generations internet cafes.
