Can I use a 125v DPDT Relay in place of a 12V DPDT Relay?
Discussion in 'The Projects Forum' started by Gamedojo, Mar 18, 2015.
  1. Gamedojo
    Mar 17, 2015
    12
    My parts came in for my Bi-Directional Motor circuit, and I somehow didn't order the relay. The only place locally that has Relay's only has a 125v version.
    Can I use the overrated Relay? or will it not trip correctly because of the battery power being too low?
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    there is too low a voltage in your circuit to pull in the relay.
  3. MaxHeadRoom
    Jul 18, 2013
    10,833
    2,502
    Only or Maybe is if the 125v version is AC that it MAY operate on the low voltage DC, otherwise, No.
    Max.
  4. Gamedojo
    Mar 17, 2015
    12
    Thanks guys... I had a feeling but wanted to check.
  5. MrChips
    Oct 2, 2009
    12,624
    3,451
    There are separate specs for the relay coil and the relay contacts.
    Which one are we referring to?
  6. Gamedojo
    Mar 17, 2015
    12
  7. MrChips
    Oct 2, 2009
    12,624
    3,451
    No. Wouldn't work. That is a 110VAC coil.
  8. MaxHeadRoom
    Jul 18, 2013
    10,833
    2,502
    Although like I mentioned it can be done in a pinch depending on some parameters.
    Here is a sheet from Tyco relays.
    Max.
