Can I Switch Transistor from uC Output
Discussion in 'General Electronics Chat' started by circuit4pcb, Feb 6, 2013.
  1. circuit4pcb
    Feb 4, 2013
    20
    Hello to all,
    I would like to switch a solenoid with IRLU3410 (24V line). Do I need a MOSFET Driver or can I go straight into the gate from a uC (3.3V or 5V).
  2. tracecom
    Apr 16, 2010
    3,879
    1,396
    The datasheet says that a gate voltage of 2 V or more is sufficient.
  3. circuit4pcb
    Feb 4, 2013
    20
    Thanks. The fastest frequency at which I will be switching is 24 - 30kHz for 1 - 2 seconds at a time. Do you think i need a driver for this application or is this slow enough that i do not need one?
  4. crutschow
    Mar 14, 2008
    13,501
    3,375
    That may be marginal at that frequency without a driver. Are you switching so fast because it's a PWM signal?
  5. circuit4pcb
    Feb 4, 2013
    20
    Yes. I intend to open the solenoid with a pull-in current and then hold it there for some time via PWM. Do you think NC7WZ17 will do the job to drive the MOSFET switch?
  6. Ron H
    Apr 14, 2005
    7,050
    657
    2V is fine if you don't need more than 250uA (look at the spec). You need at least 4V gate drive to get guaranteed ON resistance (Rds(on)) of 0.155Ω.
  7. tracecom
    Apr 16, 2010
    3,879
    1,396
    That's one more thing about reading datasheets that I don't understand.
  8. Ron H
    Apr 14, 2005
    7,050
    657
    Do you understand it now? If not, what can we do to help you understand it?:)
  9. circuit4pcb
    Feb 4, 2013
    20
    I thought I understood everything until you mentioned the 250uA part. Can you elaborate on this please. The resistance on the coil will be between 20 and 30 ohms. Also can you provide confirmation on using NC7WZ17 as a driver.
  10. circuit4pcb
    Feb 4, 2013
    20
    Can anyone help me with this?
  11. t06afre
    May 11, 2009
    5,939
    1,222
    Eh.. did I read you correctly. You want switch a solenoid at 24 - 30kHz. That sounds to fast to me.
  12. circuit4pcb
    Feb 4, 2013
    20
    This will be used as a hold voltage once the solenoid has been fully pulled-in. Do you recommend another frequency? But I would like to know if NC7WZ17 will work as a driver, and do I need a resistor in series with the driver and the solenoid.
  13. t06afre
    May 11, 2009
    5,939
    1,222
    No as hold voltage this may work very well. You could do some experiments regarding duty cycle and frequency. It could be that you can lower your switch frequency. As I do not know the full spec of your setup. It is hard to say yes or no. But as I see it now your design approach sounds correct to me.
  14. Ron H
    Apr 14, 2005
    7,050
    657
    What kind of uC are you using? Most of them can drive a logic level MOSFET directly, if the speed is not too high.
  15. electron_prince
    Member
    Sep 19, 2012
    93
    Once i used darlington pair for this purpose. No idea about FETs.
  16. circuit4pcb
    Feb 4, 2013
    20
    I have this eval board that I can play with (see link). Do you think this one will handle the PWM directly? How do you do 100% duty cycle and then switch to 50% duty cycle? Attached is the signal I am trying to achieve. 1st part will be 100 ms or so and the second will be 20 - 30 kHz. 1st part will always be a fixed time. The second part will vary depending on how long I would like to hold it. Is there a way that I can lower the voltage of the 20-30 kHz part to perhaps half the voltage?
    http://www.st.com/internet/evalboard/product/204176.jsp
  17. circuit4pcb
    Feb 4, 2013
    20
    any ideas on this?
  18. crutschow
    Mar 14, 2008
    13,501
    3,375
    To use PWM you will need to add a diode across the coil (cathode to positive side) to provide a path for the solenoid current when the switch is off and prevent large voltage spikes which can zap the transistor.
    The NC7WZ17 should work ok as a driver.
    Your link does not show the eval board.
  19. circuit4pcb
    Feb 4, 2013
    20
    Thanks Crutschow. I gues ST is changing their website so their site is down, but the evaluation board i am using is the STM3210E-EVAL. When you get a chance please let me know if you believe I can duplicate the signal below.
    Thanks to everyone for your patience with me.
  20. circuit4pcb
    Feb 4, 2013
    20
    Ok so I received the circuit board and tested it out. It is able to switch the solenoid just fine but here are a few observations. When I measure the gate og mosfet (uC output) signal looks perfect. But when I measure at the drain, the signal looks inverted. Is this what i am supposed to see?
