I need to remote start a diesel genset from a remote location but i can't work out how to approch it. What i need is something that can start the engine when i press a button or flick a switch and when button is pressed again (or switch flicked back) can stop it.
The first problem is that start and stop are not the same, when i need to start the engine i need to have Ignition ON, Glow plugs on for 10sec, Crank engine for 4sec, wait about 20sec and then switch power on.
When i need to stop it i have to remove the power, Stop engine (this is a 1sec signal for the solenoid) and remove the Ignition.
I originally built a cascade of 555 to time the starting sequence but that doesnt help the stop sequence. Now i am thinking to use logic to control the all lot and keep the 555 only for the timed sequences (glow, crank and stop). I know i could use a pic but i am not skilled to use it. I have basic electronic skills but can work with logic if the problem is not too complex.
Any suggestion?
Any suggestion?
