can i recover code of PIC16C57 MCU
Discussion in 'Embedded Systems and Microcontrollers' started by moonnightingale, Sep 2, 2010.
  1. moonnightingale
    May 22, 2010
    9
    Can u see my code and tell me that can i recover my code from
    PIC16C57 MCU
    The file is attached . u can open it in txt format
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You will need a disassembler program, or some time with a list of PIC commands to do it manually.
  3. bertus
    Administrator
    Apr 5, 2008
    15,801
    2,387
    I found this in my e-mail:
    As I do not answer in e-mails, I do it here.
    If the copy bit is set you can not read the pic.
    The copy bit can be reset by a bulk erase.
    This is only for flash pics and ALL data in the pic will be lost.
    The pic you show is a cmos (one time programmable).
    Bertus
